1 - 20 of 26 Posts
I just received my Zard exhaust today after a three week wait for their made to order low mount slip on. I purchased mine off Amazon and it was shipped 2nd day air directly from Zard in Italy (a pleasant surprise). This exhaust is built by skilled hands and you can see it in all of the individual pieces that come together to form a true work of art. Lots of attention to detail and impeccable fit and finish. I weighed the original exhaust after removal to compare the weight difference as they claim a 3.5 kg drop in weight and sure enough that is what I came up with on my digital hanging scale.
Installation was a breeze as there was only two mounting bolts and the retaining spring to remove the old unit. The new exhaust uses the same retaining spring coupled with a steel hose type clamp that affixes the forward mounted heat shield against the inlet pipe. The rear mounted bolt was not supplied and the original was too long. I had a replacement on hand as it is a popular size and I sandwiched the hanger with a couple rubber grommets to quell vibration. I painted the exhaust hanger flat black which cleans up the look allowing you to focus on the exhaust itself. I also painted the back side on the Zard badge to help make it stand out.
The sound this thing makes is impressively loud, probably louder than what most people would like and that is with the db killers in. I myself love the sound and find it intoxicating. It does pop and crackle on decel but the factory exhaust did that as well, it was just a lot quieter doing it through the cat and large expansion chamber under the swingarm. My biggest problem now is I can't stop looking at my bike and this is infringing on my riding time.
I have a couple more projects planned that will help tie it all together. One of which I will post as "Zard guard". Stay tuned as there is more to come.
Looks great, congrats. Good to know about the 2-day shipping from Amazon, as I've been looking into them. How about a video??
Looks good. More importantly though: how does it run compared to stock? Notice any difference in feeling or power?
Discussion Starter · #5 ·
My initial impression is that it revs more freely up top and you feel a little less of the abrupt throttle response at take off, which makes sense if the power curve got shifted a little (less torque more horse power?). Sounds incredible through out the rpm range.
Pleasant surprise: Better mapping with Zard low
I completely concur after mounting it this morning. Was arriving late at work cause I had to stop several times and admire my bike;). The exhaust fits the bikes style extremely well, in the flesh better than in the pics. Craftsmanship is a piece of art. The sound is very 2 cylindric now, louder, still decent, but more agressive.
Big pleasant surprise: The power/torque gain at low revs makes the engine accelerate butter smooth from 2500 U on. I can run a gear higher in twists and villages. This is a different bike. More racy, silk smooth, nobody will be overlooking you anymore when overtaking :laugh:
BTW: I have the fully homologated version with cat. I like the idea to not producing toxic fumes. I am running stock map.
http://shop.officineitalianezard.it//public/contents/imgs/cms/scrambler_ducati_slip_on.pdf
Discussion Starter · #11 ·
I would have considered the cat version but could not find any availability info here in the USA. I just noticed that my db killer inserts are different front their You Tube video. Seems they made the openings larger and no flared ends on the one I recieved. Mine also sounds a bit louder due to the larger openings. I'm guessing they could set me up with the different inserts if I asked.
Although I think the Zard "Low" looks very nice on the Scrambler, there is no way it's worth ~$750 (US, shipped), IMO. That's kind of ridiculous for a slip-on.
Discussion Starter · #15 ·
I can understand what you are saying but I was able to justify this purchase with the hopes of being heard by brain dead drivers. I felt invisible with the stock pipe and now I stand out, my life is worth $750. The attractive looks and the great sound are just icing on the cake.
Discussion Starter · #17 ·
Update: This exhaust makes my bike run noticeably cooler. It must be from the exhaust gasses exiting at a faster rate as opposed to slowly fighting it's way through the factory system raising the temperature. Anyone else notice this with the Zard or any other slip on?
I have the ceramic coated version coming, very excited, maybe another week before it arrives.
And I agree, your money to do with as you please, regardless of what others say.
1 - 20 of 26 Posts
