Note - I will split the pictures into 2 posts ( I received an error when trying to upload 9 pictures).
Objective - to use my rear stand on my Ducati Scrambler. The problem is the bike wants to slide backwards off the stand, because of the upwards angle on the bottom of the swing arm.
This mod is easy and cheap to make in a simple home workshop.
The Left side - this is real easy because there is an attachment point under the swingarm where there is a bracket that supports the OEM Number Plate Thingy. If you still have the Number Plate Thingy, my bracket just bolts onto it. Because I have a Tail Tidy I have removed my Number Plate Thingy including its support bracket so I have just substituted a couple of 18mm spacers. My bracket is fairly inconspicuous except the socket head bolts need painting black. The bracket is made from 3mm Aluminium angle.
At this stage I can put the bike up on the rear stand. My bracket on the Left side will stop the bike enough from sliding backwards off the rubber blocks of the stand. BUT - if you start wrenching, pushing, rocking the bike it will gradually start creeping backwards on the Right side rubber block.
Not good.
The Right side - There are no fixing points on the swingarm. So I attached a flat bracket to the back of the Right side pillion foot rest. There are two threaded holes already there (for some unknown reason).
I have tried to keep this bracket inconspicuous as well.
My existing rear stand is just a cheap one and is used also for my Thruxton. To the pin, on the Right side of the stand, I attached a simple adjustable link using a cable tensioner and some flat Aluminium . This assembly can pivot on the pin, but will end up acting as a solid link.
Process - I straighten the front wheel and put a small chock behind it. This just makes the bike start out nice and square when you lift it. Raise the bike on the rear stand. (Of course you start with the stand contacting the Left side swingarm first because the bike is leaning that way on its side stand.) On the right side, swing the adjustable link over and attach it to the bracket below the foot rest.. You may need to adjust its length by a couple of mm because you may not have put the stand in exactly the same place as last time. That's why the link is adjustable and takes seconds to do it. The bolt that fixes the link to the bracket only has to be finger tight. The link now stops the bike from sliding backwards, on the Right side, off the stand.
The bike seems to be very stable and I would be confident to do any repairs, cleaning, wheel removal etc.
It probably looks like a bit of mucking around but aluminium is easy to work, the 4 bolts were cheap and the cable adjuster was about $10.
Hope this helps a bit.
Let The Good Times Roll - Ray
Not good.
