After having spent the entire last week on the bike including 1000 km freeway the tires are clearly showing an uneven wear pattern. My total is now just above 5000 km. This is even more pronounced in the front. It looks like the middle two rows of knobs are made of a harder rubber. The lateral rows seem softer, they are worn down way more and they show a typical " enduro tire on asphalt" skip pattern and saw tooth shape. This results in a hearty loud knobby hum when leaning slightly in curves, loudest around 80 km/h, can also be felt in the handles. Grip is still ok though, but I am not a racer. I guess this is the reason why they recommend that relatively high pressure of 2.5/2.5 2.6/2.9 bar, because the skip pattern stems from the oscillating rolling deformation of the flanges. I did run at 2.5 front and back always. Referring to an old discussion, Jerry was right and you should definitively not run those below rated pressure on asphalt I guess. Anyway, at 6k or so I will need new tires, and I will mount the Pirelli Angel GT since I am barely taking the bike offroads. Besides they look cool and have good test results.
Pic from the French forum:
On the side: This is the best touring bike I ever rode. Totally relaxed sitting, no back pain, the stock seat broke nicely into my behind or vice versa, submarine weather no problem for the bike, and with the tank bag I am comfortably riding at 140-150 km/h on the freeway just leaning into the wind and keeping things constant. Did a trip with an old friend on a Speed Triple, I had no problem keeping up, and since he had the GPS I appreciate now even more having a cat in the exhaust. These old bikes stink when tail gating them!
Cheers, Albrecht
Cheers, Albrecht
