Does that happen at all RPM or just lower down in the rev range? At certain temps, this motor can sometimes be a little rough under 3k rpm.Hi
My Scrambler Full Throttle has now 900km on it.
From 500km until now it is stuttering when i will accelerate
Sometimes it will almost stall
Its like to have water in the carburator in old bikes
Any comments?
Thanks in advance
Agusta
Thanks a lot for sharing! It´s important to collect symptoms and fixes for a diagnose. I guess this thing could also be the culprit for some riders reporting excessive consumption and some others reporting stalls when decelerating.Update
It was the Throttle Body Sensor
They changed it and now it's super!
Better than new![]()
Guess they are having trouble receiving spare parts, factory is probably busy delivering entire bikes ...... Wonder why it took so look to identify and fix the issue?
Had another random stall today, and as I've always said it has some minor stutter like feeling when running at same speed and under 40 mph.. So maybe I should throw the dealer an email to check.Thanks a lot for sharing! It´s important to collect symptoms and fixes for a diagnose. I guess this thing could also be the culprit for some riders reporting excessive consumption and some others reporting stalls when decelerating.
That sensor is the heart and centerpiece and most vulnerable point of mixture control and it is more likely to break than the ECU since it is a mechanical part with a moving membrane.
I would book it under children´s diseases.
Keep us posted mitra. I have also noticed a bit of a regular stutter still up to about 3500+ rpm and up to 50kph or so. It's not so noticeable when accelerating, but is when you throttle back to constant speed behind traffic or local limit. It seems happier at 70/80kph. I'm waiting to see how it goes as it wears in a bit. Also whether it's temperature related - it seemed worse when I took it out at night.Had another random stall today, and as I've always said it has some minor stutter like feeling when running at same speed and under 40 mph.. So maybe I should throw the dealer an email to check.
