So I've had my sixty2 probably 6 months now, and ever since I brought it home it hasn't been starting like I assume it should. It try's to fire then stalls, then each start it idles a little more before stalling again. After about 4 or 5 times it will actually idle, but if you touch the throttle it'll struggle again like it's about to stall. I've taken it back to a Ducati dealer a couple of times now and they come back with nothing and say they adjusted some sensors and didn't have the problem when they had it. I installed a booster plug also to try help but still having the same problem. Anyone else had this at all? I filmed it to prove to the dealer when I take it back again, started filming after it failed the first start. https://vimeo.com/197983517
