1 - 6 of 6 Posts
Hi All,
My new Icon (ODO 50 km) dispay warning sign of side stand sensor. After trying switch on-off key many times, it disappeared.
Is it significant enough to correct it at service center?
Thank you
Yes, there is a safety that shuts the engine down if it is running in gear with the side stand down.
Next time you ride, test it by leaving the stand down and shifting into gear.
Thank you for your advise. But the display shows the error from the sensor of side stand, not "side stand" warning when stand down and shifting the gear.
I tightened the cable at side stand (may be the sensor) and everything seems to be OK until now
Easily disabled, just bypass the switch with a couple of bits of wire.
Reactions: Stu
1 - 6 of 6 Posts
