Here's a run down on the Seat Concepts cover and foam install.
I removed the original cover, pry out staples. The original foam was not glued to pan.
I cut out the tool tray hump. The original and new foam was only 3/4" thick in the tool hump area. I filled recess ( tool hump) void in foam with a couple pieces of foam ( blue rectangles in photo) that I had on hand.
I have the silver fiberglass insulation on underside of seat pan. Worked great for heat reduction.
I glued the new foam in place, per SC instructions. I placed the included plastic sheet material on top of new foam (water proofing). I heated the new cover with a heat gun, helps with stretch. I stapled new cover in place. Pretty straight forward.
The new seat is wider, a little tallerand much, much, much, more comfortable. I can slide back on seat, no problem.
