connector location
I have a FT, for reference. The connector is on the right side just in front of the swingarm. Once you disconnect, you can actually run the source wire under the seat and quick connect to a NEW tidy tail license plate holder. You'll have to cut a couple of zip ties to free up the source wire to do this. New Rage Cycle has a pretty slick Tidy Tail assembly that tucks your license plate under the seat and also replaces the stock signals with LEDs. I found it difficult to completely remove the existing wire that ran from the old "hugger" light holder to the quick connector, because it's tied down under the bike in 2 places with hex nut clamps that are really hard to reach without houdini skills. So....I cut mine when I removed the ugly grabber, since I had no further need for that part of the wire. Hope this helps.
