oldie from Norway
1967 Views 5 Replies 5 Participants Last post by  pacman
haven't had a bike since 1983 - so about time to start driving again.
I'm 6'3" tall (190cm) and weighs 200 pounds - will a Scrambler be a bit small for me?
:confused:
1 - 6 of 6 Posts
Welcome to the forum Old Cowboy,
I am sure some one will be able advise you, with regards to the size.
I have yet to see the bike in person.
:confused:
Hi Old cowboy,
Welcome.
I would suggest that it is to small for you check the specification below,
Wheelbase 1.445 mm (56.9 in)
Rake 24°
Trail 112 mm (4.4 in)
Total steering lock 35°
Fuel tank capacity 13.5 l - 3.57 gallons (US)
Dry weight 176,5 kg (389 lb)
Wet weight* 192,5 kg (424 lb)
Seat height 790 mm (31.1 in) - low seat 770 mm (30.3 in) available as accessory
Max height 1.150 mm (45.3 in) / brake reservoir
Max width 845 mm (33.3 in) / mirrors
Max length 2.100 - 2.165 mm (82.7 - 85.2 in)
Number of seats Dual seat
Worth trying it out I might be wrong.
Thanks! Will have to find a dealer to try it out then.
It could just be a matter of playing with the position of the pegs. At 6'3" you are right on the border line. I would definitely make sure you take a seat on the bike first before you go buying the thing out right.
Hopefully it works out for you though.
Welcome to the forum!
From what I've heard, it probably is going to be a little small for you--definitely go see one in person as soon as you can!
1 - 6 of 6 Posts
