First alternative is the KN-153 (KN-153 - K&N Oil Filters, Oil Filter)
Basic specs of the filter from KN are useful:
Product Specifications
Anti Drain Back Valve Yes
Bypass Valve Yes
Filter Material High Flow Premium Media
Gasket Material Nitrile Rubber
Height 3.344 in (85 mm)
Outside Diameter 3.063 in (78 mm)
PSI Relief Valve Yes
Removal Nut Yes
Removal Nut Size 17 mm
Style Canister
Thread Specification M16 x 1.5
I've been looking for an alternative using this website: Motorcycle Oil Filter Cross Reference
The Ducati filter is a type 6. There are some other M16x1.5 threaded filters around with this nice flat one I've just found:
Search Part : Ryco Oil Filter | RMZ127 Oil Filter :: Ryco Filters :: Automotive Filters Australia
This filter is only 59mm long (vs 85mm - that's 26 mm - over an inch saving! and one inch less sticking out!). Unfortunately I can't find any other specs on it yet. I may have to buy one and check it out.
Bypass Valve Yes
Removal Nut Yes
Style Canister
