Hi All
I am a newb to this list. But not a novice.
I recently purchased a Scrambler 800 Classic with 4500 miles on and which has a racefit exhaust with db killer fitted and a standard air filter.
Bike runs very rough between idle and 4k after that it fine and idle is okay. But it’s not fun to ride at all, and it’s my first Ducati (I have had many other bikes though).
I have put new plugs, air filter and changed the oil. This made no difference. If I take out the db killer its maybe a bit worse.
When I turn on the ignition the dash says RACE which I assume means it’s got the Ducati can map already in the bike?
My question to you, is after reading this forum it sounds like I need to get it on the dyno somewhere and remapped. But Is what I describe a map issue or should I look for any other known issue first.
