Just like many riders, I'm waiting on my Scrambler to arrive in the states. That doesn't mean that I can't have fun and design and execute the perfect shock for the bike.
Zues, The stock shock Sags with any average rider on the bike. While great to sell it to a inseam challenged rider. The average person is just going to be continually bottoming out the stroke of the shock.That shock looks awesome and I bet it feels good when sitting on the bike too.
Don't we want some static sag?Zues, The stock shock Sags with any average rider on the bike. While great to sell it to a inseam challenged rider. The average person is just going to be continually bottoming out the stroke of the shock.
The pricing will depend on which adjustment level is chosen:Nice to see an aftermarket already on the table.
Cost of yours?
I'm going to wait to see what the other major players offer. I love Matris. And they're Italian.
The Single adjuster open jet "Streetfighter" will be $799
The Double adjuster remote reservoir will be $985
The Triple Adjuster High Speed Compression remote reservoir will be $1299
Also, There is a good possibility that a High Speed Piggyback will be available but it's still in design phase.
Also, I will have fork options just as soon as I can get a set of forks long enough to check all the design parameters.
Frankd: I'm glad that the reservoir mount is growing on you. I think that the reservoir gives the bike a classic flat track look mounted remotely. It offers a lot of flexibility that a piggy back mount does not. The best feature is that if you bought a less adjustable model shock, then upgrading is as easy as buying the different reservoir. Not having to buy a whole new shock saves money and doesn't limit a buyers choice.Awesome. I will definitely keep you in mind. The reservoir placement is growing on me; it is kinda badass where it sits - right in your face.
A full cartridge kit would be awesome. A lot of companies don't like to make full cartridge kits for bikes under $10k for some reason.
Someone used a car scissor jack placed on the rear wheel and jacked the bottom of the bike up to lift the rear of bike allowing easy access to the bottom bolt of rear shock.Ken, got the rear shock in today. Have the wrench needed to pull the lower bolt off; just need to cut it to length. I have one of those ABBA stands laying around and the adapters to my Monster is the same as the scrambler. Will this work to replace the rear suspension? It mounts on the swingarm pivot. Thanks...very excited to mount this.
Tally agree, removing the peg hanger is the way to go - most think (mistakenly) that the central bolt holding it in place is the swingarm axle - it's not, and it only takes minutes to remove.Someone used a car scissor jack placed on the rear wheel and jacked the bottom of the bike up to lift the rear of bike allowing easy access to the bottom bolt of rear shock.
I myself just removed the peg hanger as took 5 mins and allowed me to torque the bolt up correctly which you cant do using the method you are planning on. I used a front stand to hold bike upright and a scissor jack under engine block and was an easy job
