1 - 7 of 7 Posts
2016 Ducati Scrambler Sixty2
Hello,
I have the Unit Garage sidebag that I need to install. The simple instructions are straight forward stating to remove four bolts to set the rear fender back on the tire to be able to install the frame. Removing the bolts for the fender left it still attached to the bike frame. The fender appears to have a plastic lip not allowing it to slide away from the frame.
There are two additional bolts that sit below the taillight that I think may need to be removed. I have not been able to loosen them.
Does anyone have experience and success with removing the fender and installing the sidebag frame?
Please send instructions and pictures.
Thank you!
Hood Automotive tire Automotive lighting Automotive design Motor vehicle
Tire Hood Automotive tire Automotive lighting Tread
Motor vehicle Vehicle Automotive tire Automotive lighting Hood
· Super Moderator
Hi without seeing the instructions I should think that you do not remove the entire rear of the bike but simply bolt the bag carrier ontop of the original frame. Can you post picture of instructions?
This may help - ignore the stuff about wiring etc but he shows how to remove fender - bolts on side and underneath
Hi,
Here are the instructions. It
would make sense to remove the four bolts as instructed to be able to remove the orange fender, but the little lip on the fender seems to be an issue. I can’t find a way to slip the orange fender out. Hard to see that in the pictures as it looks flush at the two yellow circled bolt points. If you look at the top yellow cirlce you can see the lip I am talking about. As for the instructions, the top verbiage in English “EN” and “Fig.3_Side Frame Install” pertain. Thank you.
Font Publication Newspaper Paper Document
Font Material property Parallel Pattern Publication
Automotive design Art Font Creative arts Parallel
· Super Moderator
Hi
I think I see the issue- The instructions etc are for a Scrambler 800 which does not have the metal bracket under th seat for the number plate and light (on its own big bracket on swing arm) You will have to remove the all the bolts holding your light/ plate bracket and then you can remove the fender
Discussion Starter · #5 ·
Thank you. That is what I thought. The two bolts I have circled that “may need to be removed,” does that look correct to yiu?
Now how to kindly muscle the loctite bolts. Ugh.
any suggestions there?
1 - 7 of 7 Posts
