1 - 4 of 4 Posts
Hello All,
(I have scrambler 2019, 800)
I would like to post a video that I made yesterday.
I have an issue with heading light. When I turn the handlebar to the left. The main light is OFF. When I turn it back to the middle or to the right, the light is back.
Maybe someone can help me, "I mean, where the f**ck should I really even start?" :confused:
Thank you in advance. :)
The wiring connections to the headlight are packed tightly behind the headlight assembly. Since the light goes out when the handle bar is full in one direction, I would suspect that a wire or plug is pulled hard enough to break the circuit.
Head Product Jaw Organism Motor vehicle
Resolder the wire, put some silicone and a shrinking tube over the solder.
Make sure that the wires has enough slack when turning handlebar from left to right stop.
There's not much else to do, trying to reroute from a location that the manufacturer probably by experience know is the optimal location could cause more issues in the future.
1 - 4 of 4 Posts
