İs there any lower handlebar that does not force us to change the risers and fits the original unit?since I really need this info, I asked to the dealer to check the demo bike.
the 4 bolts clamping the handlebar are 8m while the 2 holding the "riser" are 10m
in case somebody needs to buy some risers, the handlebar is 22mm fixed diameter
So is Scrambler has a taper bar or not?Handle bars are generally 7/8" (22mm) except for Harleys and some old Triumphs that were 1"(25mm).
Taper bars are usually 1 1/8" (28mm) at the clamps, tapering to 7/8" (22mm) at the grips.
Well the Full Throttle handlebar is described as "Variable Section". So I'd reckon that it's tapered.So is Scrambler has a taper bar or not?
clamping diameter(1-1/8" | 28.6mm) to be larger than the control ends (7/8" | 22.2mm).
Will this one fit ?
Yes i think it is.Well the Full Throttle handlebar is described as "Variable Section". So I'd reckon that it's tapered.
Maybe it is suitable for a ticker bar becuase i can see some gap around the bar?the Icon, has 22mm, on the clamping area as well as near grips, I've used the gauge on it to check value
