Hello Montesir, welcome to the forum! Is the immobilizer error also referred to as the check engine light? I hate you had trouble on the first day, let us know how this goes. Looking forward to the pictures.
Usually an immo issue is in reference to the ECU not being able to detect the properly coded key. There is an RFID chip inside of the key that a sensor around the ignition switch reads when you insert your key to ensure that it is, in fact, the correct key for the bike. As far as your issue Montesir, I've got no answer for you, and that's scary as crap. Bring it to your dealer and have them scan it. Make sure the ECU isn't wonking out.Hello Montesir, welcome to the forum! Is the immobilizer error also referred to as the check engine light? I hate you had trouble on the first day, let us know how this goes. Looking forward to the pictures.
Thanks. It started by itself without doing anything. I'll give what you said a shot and might also take it to the dealership. It is unacceptable for a new bike from such a so called reputed maker to have such a major issue. I'd be interested to know what they will do.I dislike very much this forum does not allow me to edit my posts. Also, I dislike very much that Ducati uses a half-baked sockmonkey of an immobilizer system that strands riders, but that is a separate issue.
I hope this helps you get home....![]()
Any update Montesir? I'm curious to know how they fix it. Thanks!At the dealership. The error is fairly consistent. So when I drove in and the turned off and turned on again the error showed up which is good as I was able to show it to the mechanic. They're running diagnostics. Will update shortly.
Update: sorry for the late response. I took it to the dealer who couldn't figure out the problem after working on it for a couple of hours. He told me they had escalated the matter to Ducati Italy and requested a fix. In the meanwhile as a solution I have to key in a pin code to bypass the error every time I get the error. It's been a month now and no response from the dealer. This is turning out to be a shitty experience with my first Ducati.. Disappointed. Hope one of the Ducati reps on this forum sees this and responds.Any update Montesir? I'm curious to know how they fix it. Thanks!
