There are two issues with this. Firstly, the USB cable is primarily a data cable and not a charging cable, so powering the sat nav via the USB would be hit and miss at best. Secondly, when the 340/350/390 is sat in the Garmin cradle, the mini USB charging port at the rear of the unit is obscured and the so the UB cable cannot be installed anyway.Quick question for anyone using one of these satnavs. Can the underseat usb power the satnav while charging or does it only charge? This is with using a normal usb cable.
