Not sure if this has been done and posted here so I thought I'd share. The front brake and throttle cable were intentionally left to float over the instrument cluster as the did on the original 62' version. From the time I laid eyes on them I thought it looked a mess. I now run my cables behind the stem by rotating the throttle 180 degrees and removing the brake lever and looping that around as well. This works really well with the tall steel handlebars as the banjo, once rotated now runs in line with the handlebar. You can see how the grip is now rotated in relation to the left side. I choose not to try and rotate the grip over the throttle tube as to not damage it. You will also need to either drill a hole to secure the throttle clamp or detab it and run some electrical tape to prevent rotation. The upside down grip actually works very well as my finger tips grip the underside ridge giving me great grip on the throttle.
