I fitted a set of Hyperlites to the rear of the Icon. These super bright LED running, stop and turn lights really increase the visibility of a bike from the rear and were only $100.00 from my local Powersports dealer. The red brake lights can be set to either strobe continuously or strobe for 5 seconds and then go steady when the brakes are applied. I mounted them along side the stock license plate holder on the rear reflectors. I routed the wiring along the same route as the license plate light wiring so the wiring is really not visible when looking at the bike. However, doing so meant that most everything had to come off the back of the bike which really increased the install time. Once completed though it was worth the work. I'll post up a photo shortly of just the running lights on.
Some photos:
Testing the wiring to be sure all connections are good. These are bright lights! Brake lights are equally bright. Red LED running lights are on below the amber turns.
Test fitting the lights and rear fender to be sure wiring is of sufficient length and all fits correctly.
Completed:
Some photos:
Completed:
