Thanks for sharing the pics. Agree about the pics on pyramid plastic sites - they are a bit misleading. I will be installing mine hopefully this weekend.
Uses double sided adhesive stick fit pads to permanently hold the Extenda Fenda on - even in the most demanding of conditions. The double sided stick fit pads are the latest offering by European adhesive giants, TESA, aimed at trim assembly on automotive production lines around the globe.
The Stick Fit Extenda Fenda is supplied complete with a pre-cut sheet of stick fit pads along with a model specific photo of the correct layout for the pads for your bike. Also supplied are comprehensive instructions, an alcohol wipe sachet to guarantee a clean bonding surface and temporary clips to ensure a strong bond in the two extreme corners during the overnight curing process.
Looking at the used air cooled Monsters out there, most of them have road rash and the paint coming off the front cylinder.curious, was flinging crub at the front cylinder becoming a legitimate problem? Is the preemptive, cosmetic, functional?? Just curious really...
