1 - 2 of 2 Posts
Just had my 7500 mile service completed. At pick-up, I started the bike in neutral, engaged first and the bike died like the kickstand was down. This continued to happen the moment I would shift into first gear. This has never happened before. I then held the clutch in and started it while it was in first. It slipped a bit and then was fine. Rode around, all good. Parked bike at home, went back out an hour later. Boom, same thing. This happens every time the bike is cold. Once I get it going it works fine until it cools. Has anyone ever heard of this problem? If so, what is going on? It seems like the dealership messed something up.
That's not normal. Sounds like something is up with the clutch. I would call your dealer and let them know. Probably would be an easier time if you didn't leave the dealer with it, but see what they can do. If they give you an exceptionally hard time, I would make sure the clutch is adjusted properly.
1 - 2 of 2 Posts
