The Termi apparently will need remaping which is done via the technicians when fitting would assume that the Akrapovic will need the sameHas anyone information on remapping the Scrambler for either the full Termi or the Akrapovic exhaust systems? It may run pretty lean without a new map.
Stu
I don't think a technician is required for the remap with the Termi systems. They provide an upmap key - plug and play.The Termi apparently will need remaping which is done via the technicians when fitting would assume that the Akrapovic will need the same
Sorry just assuming they fit it rather than yourself from new. the technicians apparently just plug in their laptop and upload new data.I don't think a technician is required for the remap with the Termi systems. They provide an upmap key - plug and play.
The dual can Termi that comes on the Full Throttle (http://store.proitalia.com/termignoni-ducati-scrambler-slip-on-exhaust) doesn't mention a remap. Make of that what you will.TERMIGNONI DUCATI SCRAMBLER RACING SLIP-ON EXHAUST
Thrilling sound with removable db killer and full power delivery thanks to the dedicated mapping; this steel silencer with up-map key makes for an exciting ride right from the word go. Features a removable db killer and carbon fiber end cap, this slip-on silencer reduces weight while adding an aggressive exhaust note.
http://store.proitalia.com/termignoni-ducati-scrambler-racing-slip-on-exhaust
Because the Full Throttle Termi is fully homolgated and runs with a cat.The dual can Termi that comes on the Full Throttle (Termignoni Ducati Scrambler Slip-on Exhaust: 96480671A) doesn't mention a remap. Make of that what you will.
That's a good thought. I wonder - are there two versions of the Full Throttle slip-on? The listing for that one mentions that it is road legal int he EU but not the US. Does that mean that the accessory version is different from the one that is delivered on the Full Throttle spec?Because the Full Throttle Termi is fully homolgated and runs with a cat.
Reportedly these engines ran very hot in the other bikes that have used it due to how lean they are, which caused numerous overheating and paint flaking issues. So a remap would be beneficial from that aspect in addition to overall power.Would anyone be interested in ECU flashing to optimise power? I've recently learned about Don Ghul who is apparently a wizard with ECUs... Granted this isn't a race bike, but they are handicapped from the factory to meet regulations...besides who wouldn't like a bit more poke![]()
Yes,would be good,to have some more Information.I have remapped my Duc SF myself,i have lots of experience with the MagnetiMarelli ECU.I am interrested in every information about the Conti/Siemens M3C ECU of the Scramby.Would anyone be interested in ECU flashing to optimise power? I've recently learned about Don Ghul who is apparently a wizard with ECUs... Granted this isn't a race bike, but they are handicapped from the factory to meet regulations...besides who wouldn't like a bit more poke![]()
Like you said. All information is interested. I have been playing around a lot with Marelli ECU so the M3C ECU is interesting. I don't have a Scrambler yet but I need one and when I get one it will need remapping.Yes,would be good,to have some more Information.I have remapped my Duc SF myself,i have lots of experience with the MagnetiMarelli ECU.I am interrested in every information about the Conti/Siemens M3C ECU of the Scramby.
Cheers
Yes, and probably.Isn't this the same ECU as the one on the Hypermotard 796? If so, wouldn't the Tuneboy for that bike work on it?
Nope. Some dealers will refuse to do it. Panni's you could do it yourself, but this there is a little slip of paper in the box saying "REQUIRES DDS".Sorry just assuming they fit it rather than yourself from new. the technicians apparently just plug in their laptop and upload new data.
