2015 Icon 803cc Scrambler
The Icon is the starting point from which to express yourself. It is characterised by its comfortable riding position and steel teardrop tank with interchangeable aluminium side panels. The 790 mm seat height ensures comfort for both the rider and passenger. Stand-out features include the wide handlebar, the headlight with glass lens and LED guide-light, and the Dual Sport wheels. An aluminium finish for the belt covers, the heat guard and the interchangeable surround of the characteristic LCD instrument panel all enrich the style of the bike. Available in two colours: ’62 Yellow and Ducati Red.
2015 Ducati Scrambler Icon Edition (Available in two colors)
Color: Red or Yellow
Components:
Low Seat 790mm
Pirelli Dual Sport tires
Aluminium fuel tank covers
Tear Drop Steel fuel tank 13.5 liters fuel capacity
10-Spoke wheels 18" Front, 17" Rear
Aluminium belt covers and heat covers
Aluminium underseat stripe cover
Passenger grab rail
Aluminium front mudguard
High and wide handlebar
Single Kayaba Shock Absorber with Preload regulation
Engine:
803cc L-Twin Cylinder
75 horsepower
Desmodromic Air Cooled Engine
Brakes:
Semi-floating mono disc radically mounted
Brembo Monobloc 4 piston calipers
ABS Standard
Electrics:
LCD Dashboard with interchangeable aluminium covers
Under seat USB
New tech LED tail light
Round headlight with LED ring
Specifications
ENGINE
Type: L-Twin, Desmodromic distribution, 2 valves per cylinder, air cooled
Displacement: 803 cc
Bore x stroke: 88 x 66 mm
Compression ratio: 11:1
Power: 55 kW (75 hp) @ 8,250 rpm
Torque: 68 Nm (50 lb-ft) @ 5,750 rpm
Fuel injection: Electronic fuel injection, 50 mm throttle body
Exhaust: Exhaust system with single stainless steel muffler, aluminium silencer cover, catalytic converter and 2 lambda probes
Emissions: Euro 3
TRANSMISSION
Gearbox: 6 speed
Ratio: 1=32/13 2=30/18 3=28/21 4=26/23 5=22/22 6=24/26
Primary drive: Straight cut gears; Ratio 1.85:1
Final drive: Chain; Front sprocket 15; Rear sprocket 46
Clutch: APTC wet multiplate with mechanical control
CHASSIS
Frame:Tubular steel Trellis frame
Front suspension: Upside down Kayaba 41 mm fork
Front wheel travel: 150 mm (5.9 in)
Front wheel: 10-spoke in light alloy, 3.00" x 18"
Front tire: Pirelli MT 60 RS 110/80 ZR18
Rear suspension: Kayaba rear shock, pre-load adjustable
Rear wheel travel: 150 mm (5.9 in)
Rear wheel: 10-spoke in light alloy, 5.50" x 17"
Rear tire: Pirelli MT 60 RS 180/55 ZR17
Front brake: 330 mm disc, radial 4-piston calliper with ABS as standard equipment
Rear brake: 245 mm disc, 1-piston floating calliper with ABS as standard equipment
DIMENSIONS AND WEIGHT
Wheelbase: 1,445 mm (56.9 in)
Rake: 24°
Trail: 112 mm (4.4 in)
Total steering lock: 35°
Fuel tank capacity: 13.5 l - 3.57 gallons (US)
Dry weight: 170 kg (375 lb)
Wet weight*: 186 kg (410 lb)
Seat height: 790 mm (31.1 in) - low seat 770 mm (30.3 in) available as accessory
Max height: 1,150 mm (45.3 in) / brake reservoir
Max width: 845 mm (33.3 in) / mirrors
Max length: 2,100 - 2,165 mm (82.7 - 85.2 in)
Number of seats: Dual seat
Components:
Low Seat 790mm
Passenger grab rail
Engine:
75 horsepower
Brakes:
ABS Standard
Electrics:
Under seat USB
Specifications
ENGINE
Emissions: Euro 3
TRANSMISSION
Gearbox: 6 speed
CHASSIS
Rake: 24°
