2015 Classic 803cc Scrambler
The Classic version is aimed at those who appreciate attention to detail and 1970s style, but who don’t want to compromise on riding pleasure and the functionality of a modern bike. It is characterised by unique, refined details, such as the aluminium front and rear mudguards, the spoke wheels and the brown seat with diamond-shaped inserts. In Orange Sunshine.
The 2015 Ducati Scrambler Classic Edition
Color: Orange Sunshine
Components:
Vintage seat
Pirelli Dual Sport tires
Aluminium fuel tank covers
Tear Drop Steel fuel tank 13.5 liters fuel capacity
Spoked wheels 18" Front, 17" Rear
Aluminium belt covers and heat covers
Aluminium underseat stripe cover
Passenger grab rail
Aluminium front/rear mudguard
High and wide handlebar
Engine:
803cc L-Twin Cylinder
75 horsepower
Desmodromic Air Cooled Engine
Brakes:
Semi-floating mono disc radically mounted
Brembo Monobloc 4 piston calipers
ABS Standard
Electrics:
LCD Dashboard with interchangeable aluminium covers
Under seat USB
New tech LED tail light
Round headlight with LED ring
Specifications
ENGINE
Type: L-Twin, Desmodromic distribution, 2 valves per cylinder, air cooled
Displacement: 803 cc
Bore x stroke: 88 x 66 mm
Compression ratio: 11:1
Power: 55 kW (75 hp) @ 8,250 rpm
Torque: 68 Nm (50 lb-ft) @ 5,750 rpm
Fuel injection: Electronic fuel injection, 50 mm throttle body
Exhaust: Exhaust system with single stainless steel muffler, aluminium silencer cover, catalytic converter and 2 lambda probes
Emissions: Euro 3
TRANSMISSION
Gearbox: 6 speed
Ratio: 1=32/13 2=30/18 3=28/21 4=26/23 5=22/22 6=24/26
Primary drive: Straight cut gears; Ratio 1.85:1
Final drive: Chain; Front sprocket 15; Rear sprocket 46
Clutch: APTC wet multiplate with mechanical control
CHASSIS
Frame:Tubular steel Trellis frame
Front suspension: Upside down Kayaba 41 mm fork
Front wheel travel: 150 mm (5.9 in)
Front wheel: 10-spoke in light alloy, 3.00" x 18"
Front tire: Pirelli MT 60 RS 110/80 ZR18
Rear suspension: Kayaba rear shock, pre-load adjustable
Rear wheel travel: 150 mm (5.9 in)
Rear wheel: 10-spoke in light alloy, 5.50" x 17"
Rear tire: Pirelli MT 60 RS 180/55 ZR17
Front brake: 330 mm disc, radial 4-piston calliper with ABS as standard equipment
Rear brake: 245 mm disc, 1-piston floating calliper with ABS as standard equipment
DIMENSIONS AND WEIGHT
Wheelbase: 1,445 mm (56.9 in)
Rake: 24°
Trail: 112 mm (4.4 in)
Total steering lock: 35°
Fuel tank capacity: 13.5 l - 3.57 gallons (US)
Dry weight: 170 kg (375 lb)
Wet weight*: 186 kg (410 lb)
Seat height: 790 mm (31.1 in) - low seat 770 mm (30.3 in) available as accessory
Max height: 1,150 mm (45.3 in) / brake reservoir
Max width: 845 mm (33.3 in) / mirrors
Max length: 2,100 - 2,165 mm (82.7 - 85.2 in)
Number of seats: Dual seat
Components:
Vintage seat
Passenger grab rail
Engine:
75 horsepower
Brakes:
ABS Standard
Electrics:
Under seat USB
Specifications
ENGINE
Emissions: Euro 3
TRANSMISSION
Gearbox: 6 speed
CHASSIS
Rake: 24°
