1 - 18 of 18 Posts
My goal is to take the scrambler more in a cafe racer direction, and the largest part of this involves removing the stock bars and fitting clip-ons.
I understand this is going to be a lot of work, so this is to help me plan, source parts and finally do the conversion.
From what I can see, what needs to be done is:
1. remove stock bars
2. relocate instruments, ideally centrally mounted. this requires a new mounting bracket
2a. relocate ignition barrel, to make room for instruments
3. modify or ideally replace top triple clamp
4. install clip-ons
4a. re-route wiring, brake lines and control cables
4b. modify or replace wiring/lines/cables if required for clearance and functionality
Am I missing anything?
Has anyone done this and can give me a head-start on sourcing parts.
Thanks in advance.
Nothing is impossible of course but from a quick look at my bike I think you're giving yourself a bloody expensive project there. Firstly there isn't a lot of clearance at the top of the forks for the clipons to fit, as in behind the headlight shroud. Second: the right hand controls on the Scrambler a pretty wide/long, so you'd need either really wide clipons or change some of the controls to narrower items. Third: pretty sure you would need shorter throttle cable and brake hose at least, they are pretty long even with the standard bars.
On the bright side, if everything above is sorted I reckon they would clear the speedo so you wouldn't have to worry about relocating it and the ignition barrel unless you want to do that for looks too.
Have you thought about clubman style bars? Gives you that cafe racer look still but maybe a little easier.
Yes, it is a big job, especially for somebody with my level of skill (ie. low).
I thought of the clip-on clearance issue, with the head of the bar section. This can be overcome by using an adjustable riser style clip on, that way all the bulk is out to the sides with only the mounting clamp around the fork leg.
Flat or clubman bars are an obvious easy solution, and my 'plan B' should this get too hard. But I would love to make something a little different and unique, finally make some of the ideas in my head a reality.
mettize has a DIY kit available for the Scrambler for about € 3000.
Crikey, that's a lot of Euros! (site is currently down, so I'll have to see what you actually get for your money later on).
I'd go for plan 'B' first and see how you get on with the riding position. I put clip-ons on my DR650 and it wasn't much fun on the daily commute! Plus clearance with the tank will possibly be an issue.
I'm much happier with the old bars back on!
Discussion Starter · #11 ·
Riding position won't be a problem. I came from a Kawasaki ZX-7R, which has a very long reach to the controls. But with the Scrambler you can't get too aggressive because there isn't very much tank to grip with your legs :) Rear sets would help with this, but I'll see how I go with a mild rise on some clip-ons first.
Tank clearance is surprisingly fine.
Not the way this monkey is built :D. Rear sets, yes.
Spend alot of time on my rides trying to visualize where I want my hands and body position. Must look like a nut to people behind me at times.
Don't you wish you could test ride the final product before you start?
Should be a fun project :)
Instead of spending all this money and time, maybe you could also consider seeing if this handlebar / slip-on kit would work on the Scrambler?
It's designed for the Monster 696 but there's a good chance it would fit or could be adapted to the Scrambler. My mate has it on his 696 and it looks like clip-ons but retains some height and it's a beautifully designed and machined bar!
http://www.woodcraft-cfm.com/cgi-bin/commerce.cgi?preadd=action&key=12-16
Another inexpensive way to get the same riding position is to go with a clubman style bar. Not as clean but very inexpensive.
1 - 18 of 18 Posts
