1 - 2 of 2 Posts
I have a ducati scrambler motorcycle. I have a clutch problem. When the engine of this motorcycle is cold, I boot up and hold my hand clutch to use the gearbox. I started on the first number of the gearbox, still holding the clutch, but the motor still moving. At first I thought it was still clutch stick. But the phenomenon disappeared after the motorcycle was about 30 minutes. The clutch phenomenon is completely disappeared when the engine heats up. I brought my motorcycle to the dealer for inspection and they had to replace the new clutch because it was worn out. But as far as I know the clutch gets stuck when the engine heats up, not when the engine cools.
Has anyone ever experienced a scrambler like that? And is there a way to explain and fix it?
You've got the answer on the other forum. There is no need to create second, exactly that same thread here, thus stick to the original one.
1 - 2 of 2 Posts
