There is a lot of rubbing going on and the rubber sleeve on the clutch cable is almost chewed through. This looks to be a long term issue that likely affect most if not all bikes
For now a 2mm thick self adhesive rubber piece is in the contact area though you can see other rub points as you turn from lock to lock
