I gave my Icon the once-over on sunday - cleaned, checked tyre pressures, etc. I've just bought an Abba stand, (it works very well), which lifts the back wheel and allowed me to clean and inspect the chain a bit more carefully than I've bothered to do before now.
Rotating the back wheel revealed no tight spots at all, so I thought I'd take a moment and adjust the chain carefully. The spec in the handbook is 27-29mm slack at mid point of the bottom run - I've never had a bike with such a tight adjustment tolerance before !
Anyhoo, I adjusted it carefully and got it pretty much spot-on.
I've had a couple of rides since and the difference this has made to the on-off throttle transition is remarkable - it's now very much smoother. The throttle is still very responsive, as so many people have noted, (personally I like it), but the "snatch" has gone.
Worth spending a few minutes getting this right I think...
Jonny
Jonny
