No matter how I try I cannot adjust the mirrors on my Icon so that I can see anything that is behind me. So far it's my only real criticism of the bike. Anyone else having this issue or?
There is another bolt right under the rubber cover that allows better calibration. Have you tried that too ?No matter how I try I cannot adjust the mirrors on my Icon so that I can see anything that is behind me. So far it's my only real criticism of the bike. Anyone else having this issue or?
I had to rotate the levers too, did make it a bit awkward for the clutch :|I'll try that but I'm concerned that will make my levers end up in an awkward position. I'll post up soon as I've tried it. Thanks
I ride Vespas, so awkward lever positions (clutch lever) is pretty normal to me. As long as it's not pointing at me, I can use it. But thanks for clearing it up. For some reason in that thread I was led to believe that you did have to loosen the levers to adjust the forward/backward mirror stalk.I'm over this so last time:
I can't believe some of you are moving your levers to awkward positions just to adjust the mirrors. The vertical adjustment is at the mirror itself, read my old post again carefully and try it.
Ducati Scrambler Forum - View Single Post - What I don't like about the Scrambler
JBS...., thanks to your recent posting, I found this thread & link for making vertical adjusts to the mirror. I have the same rear view issue. I just completed the adjustments (about 20 mins.) per Doc59's instructions & will test the results tomorrow for effectiveness.I just got a Scrambler and find the inability to see behind me a hazard. I found a part from SWMotech on Twisted Throttle that raises them.
Part # SVL.00.505.101 (or 504 depending on the thread)
Skulls, what's the difference between the two eBay links provided? Were you trying to link another part? I'm interested in purchasing these, but just want to make sure I get the right stuff.I was having the same issue, not able to see directly behind me. No adjustment of the mirrors ma a difference.
I looked at these, but they seemed pretty pricey for what they are.
I found this and this on ebay. $26 USD, ten minutes to install and adjust them. Took them out for a test ride today along with my new comfort seat). Great visibility behind me. Best money that I've spent on the bike so far.
The right hand mirror is reverse threaded, the left hand mirror is standard. It's not clear from my reading if all Scramblers are that way, or just some. But mine is, so I needed on of each.Skulls, what's the difference between the two eBay links provided? Were you trying to link another part? I'm interested in purchasing these, but just want to make sure I get the right stuff.
Sent from my MotoG3 using Tapatalk
