Realisticaly, don't think it will happen mate. You might have to look at racks and jerry cans or strapping a fuel bladder on if you want to do long distance between fills.
agree, that is very unlikely as it would completely change the aesthetics of the bike the OEM tank is aa big part of the charm of the bike.Realisticaly, don't think it will happen mate. You might have to look at racks and jerry cans or strapping a fuel bladder on if you want to do long distance between fills.
With a pod filter instead of the air box, there's plenty of room under the tank to make it deeper. That single fuel injector throttle body makes this viable. I reckon you could modify the std tank by cutting out the underside and dropping it down.Im my opinion depending of many bikes well be sold, the acerbis and ims company may produce larger tanks, like they do to off road bikes.
Lets, see if the scrambler will be a sailingh hit
Agree, and another gallon (4L) would make a huge difference in range.With a pod filter instead of the air box, there's plenty of room under the tank to make it deeper. That single fuel injector throttle body makes this viable. I reckon you could modify the std tank by cutting out the underside and dropping it down.
That should get another 4 litres or so AND lower the CofG.
The pod filter would also mean the bike is better for off road in that it would be far easier to pull an oiled filter 'condom' over the pod so you could change that mid ride when it got dusted up. If you don't already use one of these; a hair net works really well.
I'd trade a little of the aesthetics for a bit bigger tank. It can be a long way between drinks out here. Need any racks I can get on for luggage.agree, that is very unlikely as it would completely change the aesthetics of the bike the OEM tank is aa big part of the charm of the bike.
You might want to consider also a Rotopax tank attached to a rack or ride rack. they work quite well
That's a valid point in some places but here in New Zealand there are some places where you can travel around 200km and not find fuel. If you were in those areas and had already used half a tank; you'd be in trouble.where are you going to travel it you need such long range? In EU there's a gas station every 20-40km
MJ
