Trying to fit a Battery Tender Jr quick disconnect to the battery. How do I get the cover off to expose the battery terminals?
I got the rubber strap unhooked on one end now can't get it to reconnect?
Thanks
Terry
Your dealer did that - not all do...My bike has a battery tender plug already installed on the inside of the left side forward frame, you don't have that?
Ok you chaps from across the pond what is a battery tender plug?
Cheers
England
Thanks for the clarification Jerry, I have a Ctek charger fitted, not needed it as yet unlike the MVI'm guessing it's the equivalent of an Optimate lead for one of these:
Optimate 4 Dual Program Can-Bus Compatible 12V Motorbike Battery Charger
Brilliant product, I've got one for each bike.
Good chance of that being such a necessary feature to have on the bike. Too bad there doesn't seem to be an online version of the manual somewhere.I thought I read somewhere that the manual references having the battery tender plug?
If it did, and mine doesn't, it will only fit a Ducati charger and I would guess anything with an identical plug. There's no global standard so if it didn't fit an Optimate I'd be ditching it anyway.I thought I read somewhere that the manual references having the battery tender plug?
Please doMy UE came with a pre rigged plug that is not directly Battery Tender compatible however my dealer gave me a Battery Tender adapter plug for no charge, probably a $30 part. I can post pics later if anyone is interested.
Mine came with the SAE2 installed from the dealer. I specifically asked them for it, but I believe they said they install them for all new bikes they sell. I have them on all my bikes with batteries and leave them on a tender to keep the battery fresh especially the Monster because the battery is a PITA the replace.Are you gents referring to the SAE 2 connector? I go around fitting it in all my bikes and was planning to fit one in my Icon too. I have at least 3 uses for it:
a) Power my Slime Tire Inflator
b) Power my 12V pressure washer
c) Connector for my Maypole charger
If it came pre-installed that would be awesome. Will take a peak one of these days.
SAE 2 Connector:
I do not believe that the yellow plug you mention is a "battery tender/charger connector" as the charger connector only requires 2 leads: + positive and - ground which are each attached directly to the + and - terminals on the battery.My UE came with a pre rigged plug that is not directly Battery Tender compatible however my dealer gave me a Battery Tender adapter plug for no charge, probably a $30 part. I can post pics later if anyone is interested.
Just to be clear, does that black adaptor cord plug onto the Yellow port with the other end going into the battery tender? This yellow port is what hooks the bike up to the DDS at the dealer, and it was my understanding that this is used for data, not power.Here is a pic of what is under the seat on my UE. I am in the U.S. but don't know if that makes a difference. The plug in on the bike (yellow part) has a locking black cap. It looks like it would be, and it might be some sort of other diagnostic connector as well. On the left is the adaptor the dealer gave me to hook up my battery tender over the Winter although I intend on riding it enough even then to not really need it.![]()
