1 - 1 of 1 Posts
Hi all,
I have read through the other incidents. I was lucky in that i was facing my condo building when I looked down and all the fuel was pouring out. I had just got done being a little sporty with the bike.
Now the question....My service guy(unaware of the common problem) simply reattached the fuel line to the fuel pump and sent me on my way. I didn't think anything of it and hadn't read about this problem as of yet.
The bike lost some power I believe. It seems to be softer in the mid and the most telling thing, if i sat upright before, and gave it full throttle in first gear the front tire would come up hard enough to flip over without a correction. Now the wheel doesn't come off the ground unless I work it a little and then just barely.
Should the fuel pump have been replaced? Is it possible that incident cause the pump to not work as strongly or something else related?
I asked the service tech to look into it as well.
FYI the bike has the up map and termi.
1 - 1 of 1 Posts
