1 - 5 of 5 Posts
Hello everyone
I’m new member and new biker too
I just bought the 2016 scrambler icon and the front wheel mess up also the tire need to be replaced too ( I’m still not replaced new tire yet) so I take off the front wheel go to fix first then put it back , I ride test about 5 minutes the abs light and the engine light show up with error, so the problem is the wheel not balance or something is the cause of this error?? Please help me thanks you.
Hi
Check the sensor and abs ring - make sure you did not damage it when you removed the wheel
Exactly what you said , the guy who fixed my wheel somehow bent my abs rotor so I use flat head screw driver bent it back as normal as I can and … ta daaa problem solved…… thanks again Christ for helping me out of this.
problem solved Thank you
1 - 5 of 5 Posts
